Separate flow ratio for infill vs walls
As per the title really, can we get a separate flow ratio for infill vs walls?
I guess this could sorta go along with the requests for seperate material for infill vs walls as it could be done in the slicer that way - but plenty of my prints have infill twice the extrusion width that the walls are, which leads to a little more hotend pressure and slight underextrusion even at the same flowrates - it’d be nice to have a modifier just like we already have for bottom and top surface flow ratios, but for the infill, to be able to correct for those situations and similar.
I would also like this because my top surface is overextruding but my walls and bottom surface are fine. I suppose this could also be implemented in OrcaSlicer
You can already modify the top surface flow rate using the multiplicator in the Quality tab.
But it’d be good also be able to adjust the sparse infill flow. It gets a bit messy when using combine infill.
I also wanted this for Foamin ASA filaments, where I would like to be able to vary both the flow rate and the temperature for Walls and filaments - with Foaming ASA you can increates linewidth dynamically with temperature, so dropping the flow rate and increasing temp allows you to have less dense lines in your infill.
