Set up a maximum fan level?
Hi!
Is there a way to set the P1S up so that e.g. the parts fan never exceeds 80%?
I turn it done from 100% manually everytime because of the noise and was wondering if somehow I can set 80% as a default max in the settings.
Thanks,
Dan
You should be able to set the maximum fan speed in the filament settings under the cooling tab.
I believe to make it a default setting, you would have to do this for all filaments though.
As @RMB said, see here : Auto Cooling in Filament Settings | Bambu Lab Wiki
Scroll down to the part cooling bit.
If you set in Bambu studio against specific filament, will that always be used when that filament is selected - even if you send a print from the mobile app or over the cloud (ie not using studio to send it)?
