Settings for Sunlu TPU
I’m only in my third week of 3D printing with my X1 Carbon and I need to make a small part using TPU. I ordered Sunlu TPU from Amazon. Reading the WIKI, it says you can use the Bambu settings if it’s got a hardness of 95A or higher. Sunlu TPU is rated at 95A. The WIKI goes on to say you can adjust the Print Speed from the Bambu setting. The recommended Print Speed for Sunlu is 20-40 mm/s.
I think I’ve got a good starting point, but I’d really like to hear you you guys/gals who have used this filament and the settings you use. I’m assuming you also use the Cool Plate, but correct me if I’m wrong. (I also know not to use the AMS with TPU)
Thanks for any help.
Hi,
  1. Dry your filament - !Critical!
  2. If you want good results, calibrate it ( flow dynamics and flow rate).
  3. Generic TPU profile works.
  4. Do not use AMS.
  5. Any build plate will work.
Depending on the part, I wouldn’t say any build plate will work. Well, some work better than others. I prefer to use the Engineering plate with glue applied. Makes removing TPU parts much easier than on a PEI plate.
The TPU is still in its vacuum packed package with desiccant inside. Shouldn’t it be dry enough? I would think so.
If I use the Engineering plate, what temperature should I use on the plate?
Will I be ok using 20 mm/s for the Print Speed or just use whatever the Generic profile has listed?
Just a follow up to let folks know that I used the Generic TPU setting, changing only the nozzle temperature range to what Sunlu specified. Used the Cool Plate and my print came out perfect.
Thanks everyone
What temperature worked best for you?
Set it to 195-205 and let the printer do it’s thing.
I am on my 13th straight TPU failure on my X1C. I have mostly only used Bambu filaments and likewise I am using Bambu Lab TPU 95A HF and started with Bambu’s predefined settings and this was the first time I found that the build-in settings not working.
I would not recommend using Bambu’s TPU settings even when using their filament.
In my effort of troubleshooting I found better setting for a TPU Benchy on Printables which helped and at least got me to the point of getting halfway though the first layer. Now the print just fails about halfway though printing the first layer, it’s multiple parts and usually fails around end of the 3rd or during 4th part).
After fixing the settings, and still getting failures, I suspected that maybe the spool was getting hung up and causing slipping in the extruder. I have my spool in a Sunlu filament dryer which a PTFE tube adapter so I can feed the filament as dry as possible straight to the side feed. After I load the filament I extrude enough length and watch the spool make a full rotation to verify the filament doesn’t just have slack that gets tensioned halfway through the first layer (i.e. I make sure the tension on the filament is the same when starting), so that doesn’t seem to be the issue.
My best guess at this point is that I still need to further fine tune the settings since I’m trying to print long narrow strips, but I don’t know really.
If I can conclude anything from this it is that the Bambu 95A HF TPU is just a gimmicky product. I do not think it can realistically print any faster or easier than any other similar shore TPU.
I’ll order and try a different brand TPU to see that is any better to print with the same setup.
Don’t know about anybody else, but I’m using Sunlu PLA on the Bambu PLA Basic settings and everything is fine.
Feeding TPU out of a hot dryer can cause issues because it’s softened.
I used SUNLU Highspeed TPU 95A and used their Bambu TPU HF 95A profile and only changed what you did, nothing else and it is printing perfectly.
I am sure I could do some calibrations to get more flow and speed, but I have never done that before and honestly it is printing really fast already, looks almost the same as any other filament honestly, I figured it would be slower lmao. my first print is a socket extension holder on .16 layer height and takes 50 minutes, not bad atall…very impressed it was that easy…super stoked…I raw dogged it on the Textured PEI, so I got my fingers crossed it will come off easily, I don’t want to mess with glue if I dont have to, that is why I usually just use the Textured plate and the texture is really nice on tool boxes and stuff so you dont have to worry about the flat shiny surface getting scratched up.
I noticed a few people asking for a working profile for Sunlu TPU 95A on Bambu printers but nobody posted one. I’ve been testing and tweaking mine, so here’s what I’m running. It’s not perfect for every machine, but it’s a solid starting point. It cut out the stringing I was seeing and the print quality is much improved.
Filament settings
  • Type: TPU
  • Diameter: 1.75 mm
  • Flow ratio: 1.0
  • Density: 1.22 g/cm³
  • Nozzle temp: 200 °C (spool range is 190–210 °C, adjust as needed)
  • Bed temp: 50–55 °C
  • Max volumetric speed: 4.5 mm³/s (can push toward 6 if your printer handles it)
Speed
  • Initial layer: 20 mm/s
  • Outer wall: 35 mm/s
  • Inner wall: 45 mm/s
  • Small perimeters: 40%
  • Sparse infill: 50 mm/s
  • Internal solid infill: 45 mm/s
  • Top surface: 30 mm/s
  • Bridge: 20 mm/s
  • Gap infill: 25 mm/s
  • Support: 35 mm/s
  • Support interface: 25 mm/s
  • Travel: 150 mm/s
Retraction
  • Length: 0.8 mm
  • Retraction speed: 25 mm/s
  • Deretraction speed: 25 mm/s
  • Wipe while retracting: On
  • Wipe distance: 0.6 mm
  • Z hop: Off (enable 0.2 mm if you see smearing)
Cooling
  • No cooling for first 2 layers
  • Fan speed: 30–50%
  • Overhangs/bridges: 100%
  • Aux fan: 50–60%
Acceleration
  • Normal printing: 2000 mm/s²
  • Outer wall: 1500 mm/s²
  • Inner wall: 1500 mm/s²
  • Top surface: 1500 mm/s²
  • Travel: 8000 mm/s²
  • Initial layer: 500 mm/s²
Notes:
Start with 200 °C nozzle / 55 °C bed. If you still get stringing, try dropping nozzle temp a few degrees at a time. TPU doesn’t like long or fast retractions, so keep them short and slow. Travel speed helps keep strings under control, so don’t lower it too much.
man you’re the best , thanks for the settings
Tried you recommended settings for my first-ever TPU print….came out perfect!!! Thank you so much!!!
generic tpu with a volumetric flow of 2 mm3/s
works, but prints slow, but it works 100% fine (I use it for “battlebot” chassis)
you MUST dry your filament
Giving this a try right now on my first ever TPU print.
dsmith360
My first, and so far only, TPU print I used SUNLU TPU 95A and the recommended settings. I got a great print. But I nearly had to use a jackhammer to get it off the build plates. Used both a Textured PEI plate and a smooth hot plate at 50C with same results on both. Thought I was going to have to buy new plates for both.
Any recommendations?
Glue on the plate helps with TPU removal. Hair spray works for some; I may have used the wrong kind or amount, but it did not work for me.
Ten minutes in a freezer also helps release the model from the plate.
Used your methodology and got several good prints. The glue and freezer advice did the trick.
I print regular TPU as the generic profile in bambu studio. works, but i admit it could be tuned better. but it does work.
