Settings to reduce some stringing
Hi guys - I’m using a new filament - Overture PLA turbo with the generic pla high speed profile.
It works well but I’m noticing very fine spider web like filament in places. Nothing too bad.
What is the best settings to adjust to try and remedy this?
I’m thinking about lowering the temp slightly and adjust retraction distance, speed,
Just wanted to see what increments may work without too much trial and error if someone has experienced something like this.
Thanks
Hi!
To reduce fine stringing with Overture PLA Turbo:
Temperature: Lower it in small steps, like -5°C at a time. Aim for 190-215°C.
Retraction: Adjust retraction distance by 0.2 mm steps (around 5 mm for Bowden, 1-2 mm for direct drive). Also, increase retraction speed by 5-10 mm/s, trying between 25-45 mm/s.
Travel Speed: Bump it up to 150-200 mm/s to reduce oozing during moves.
Try these tweaks, see how it goes. A quick heat gun pass can also clean up any leftover strands.
Perfect thank you - just lowering the temp -5c worked! Appreciate you!
