Settings used on the BambuLab Badge
Hello,
I have been trying to recreate the smoothness of the top layer that is on the preloaded BambuLab Badge. I am using the same filament. I have been playing around with the ironing features but I cannot seem to get it as smooth. Does anyone at Bambu have access to the settings that were used to create this? or is there a way I can import the badge into studio to get its settings?
kind regards
John
In case you don’t have it, the file is here. I don’t know if you can reverse engineer it or if the built in is different, I just know where you can get it.
The built-in print is just G-code and can’t be extracted (at least from the X1C.) It might be interesting to see if the one on a P1P SD card has the typical comments at the start with settings.
