Several fonts not working with text tool
Sind the last upgrade a lot of fonts are no longer working and always switched back to a fallback font - Arial?.
These fonts worked before. I restarted Computer, reinstalled fonts and studio. No Luck.
Any other tips to get them working again?
The font Pricedown worked in previous versions. Then it stopped. Problem happened in both Mac and Windows. If you need the fonts go back to previous versions. Not much help, sorry.
I found the fix posted over here. [Preformatted text](https://forum.bambulab.com/t/windows-fonts-in-text-shape/26483)
I had to install the font with the option “Install for all users”. On Windows 11, I also first right click the font, went to properties and made sure the file I downloaded was “unblocked”. Not sure if this was needed, but I did that before I then right clicked the font, chose “show more options”, then selected “Install for all users”. I opened BambuStudio again and this time picking the new font correctly set the font graphic.
Have we found a fix for this? I can only seem to use that 1 default font. If you go through the entire drop down menu maybe 2 or 3 fonts might actually work but all of the other ones revert to whatever the default font is. Its getting annoying not being able to easily add text on an object. Maybe I should just try this Orca slicer everybody is hyped on recently but I bet that has a similar issue cause theyre built from the same OS software.
Just FYI. I had the same issue with a font defaulting to Arial - and I tried both the Bambu Studio for Windows & Mac and none of them worked.
I then installed Orca Slicer v2.2.0 and it works instantly :slight_smile:
Bro thank you so much! It worked
Smoke’s answer worked for me if you didn’t see it.
This fixed my issue! I use a font for my business, which always work with Prusaslicer, but this same font would not work in Studio until I followed your instructions - “Install for all users” was the issue! Thanks so much for sharing!
I’m having the same problem in that I cannot change the fonts in the text tool, which makes it pretty much useless!
I’m running the latest version of Bambu Studio on an M4 Mac, which means I cannot try the fix suggested above.
Any ideas? TIA
Try adding the fonts to /Library/Fonts and NOT ~/Library/Fonts, that resolved the issue for me.
Also make sure the fonts are either .ttf, .otf or .ttc.
How does moving the fonts affect other apps using the fonts? Will they find them ok? Or are you saying put a Copy of the fonts into that folder?
I’m on a Mac.
Same. On MAC. It seems like no fonts work.
My BambuStudio only recognise the font up until Leter L, is there a limit that software is not able to read? I have around 11000 fonts and others machines software recognise them but not bambu studio… it just finish at letter L… and is installed as per all users… any help please?
I have this issue still on some fonts especially when copy and pasting a whole object and parts but altering the text.
Not exactly a fix but a work around I found that worked for me was to toggle bold and/or italic on and off which seemed to revert back to the chosen font.
Hope this helps those that still have the same issue after other suggested solutions.
Well this fixed my text bugs… thanks! :slight_smile:
