Shadowbox Maker Release!
2025-03-12 11:25
Turn flat images into stunning 3D layered art in just a few steps.
Simply upload an image, use our intuitive tools to add depth and export a 3D-printable model-perfect for gifts, home decor, or creative projects.
Click HERE to start crafting.
You will have to forgive my first impression of hueforge on steroids , looking forward to trying this
Fawn in the forest shadowbox by MXBCTMM - MakerWorld
First example found on @MakerWorld
Just a small tip in case you want to improve the surface finish of your prints (the top layer).
1º Calibrate the flow with a test in Orca Slicer (it is an almost automatic test).
2º Calibrate also the temperature for a uniform gloss.
3º Use the top fill with Monotonic pattern (for smooth surfaces without marks) or with Hilbert Curve pattern (for surfaces with very nice geometric finish).
4º And finally, don’t be in a hurry, the top layer can be printed at 60-80mm/s to improve the finish and gloss.
Good luck!
Edit: I just noticed it’s not your design hahaha, anyway I leave the comment in case it’s useful for someone.
forgive my ignorance, why calibrate the flow in orca slicer, and not in bamblu slicer? And do you mean Flow Dynamics or Flow Rate (or both?) @Eleazar_3DinPlastic
I’m playing with it now as well, looks really interesting!
the formatting of the images is very tricky however, it failed to accept the more complex ones I used in the litho I posted. In testing it likes muted backgrounds and more “cartoon” styling it seems.
So that being discovered I had my Ai whip up a ton of MH logo and text - I hope this box maker thingy can convert them it would be super cool.
EDIT:
It’s quite tricky!!! simplistic designs will be best but phew!
It doesnt working for me, I have tried more browsers and it just dont make the layer down there and it is empty. I also cannot add another :frowning:
Same here, doesn’t work. Even the tutorial doesn’t work either
Fairy on the moon Step Layers of Dimensional Art by Tala16 - MakerWorld
Experiments
Great ideas often start from a very inelegant prototype. MakerLab Experiments is where we invite our enthusiastic users to play around with the immature prototypes and witness the long journey from a brainstormed idea to a polished product.
Try getting in touch with mw support if you are having issues
I can’t get the tutorial to work either
Same. It isn’t working. Tutorial just freezes at step 3/5. Selecting anything with the magic wand and nothing happens.
I am getting better at using Shadowbox maker but have an issue where one layer has a very small connection to the frame. I think it is likely to break.
Is there a way to add connections manually or add material to make the small connection larger?
I have gone through the tutorial a few times successfully but still have some confusion on what assembling and connections are or do.
I have the same issue. I tried a different laptop and it works. I don’t understand the difference in setup between the two.
I think I could use a few definitions and clarifications. For example:
“Ensure the first layer is assemblable, and then add areas to each subsequent layer based on the previous layer and ensure assemblability.”
  1. Is the first layer the one in front or back?
  2. What does assemblable mean?
  3. What is a connector?
  4. If I select a section in the image, does it have to have a connection to the areas around it or can it be free floating?
I have had partial success with a shadowbox but one issue that I have is one of my layers has a very small connection to the frame and could easily break.
I have the same issue with the shadowbox get to 3 of 5 and nothing happens. I’ve tried multiple browsers i could try a different laptop, but it has lower specs than what I’m using.
doesn’t work for me too with different browser .
Doesn’t work for me neither and no info found about this specific error
Ciao… dove trovo il programma
MakerLab
