Studio needs the ability to share printers without the added complexity of Farm Manager and associated server. It could simply be a “printer in use” message.
We have a shared H2D in our office. It might print once or twice a day. There are 5 of us that might use it. I have asked IT to network the printer and setup a Farm Manager server. They don’t want to support this. We are currently sharing via thumb drives (sneaker net). Its getting old fast.
LAN only mode sounds like the best solution. Easier to sell to the IT department and no account needed. According to ChatGBT, if I try try to print while its already printing nothing bad happens, I just can’t until its finished.
Here’s the IT department request that ChatGBT put together. It seems resonable but we have a strict IT department. I’ll report back when I get some progress.
Subject: Request to Network Bambu Lab H2D 3D Printer
We have a Bambu Lab H2D 3D printer in our department that is currently operated using USB drives. We would like to connect it to the corporate network so approximately five users can send print jobs directly from Bambu Studio.
The standard H2D does not support WPA2-Enterprise/802.1X authentication; it supports WPA2-PSK Wi-Fi. We are therefore requesting an IT-approved method to connect the printer, such as an appropriate device/IoT network or other approved solution.
Our requirements are simple:
Local network access from approximately five corporate PCs running Bambu Studio
Bambu LAN-Only Mode is acceptable and preferred
Internet/Bambu Cloud access is not required
No Bambu Farm Manager or additional server is required
The printer can be isolated from the rest of the corporate network as appropriate
The goal is simply to allow authorized users to prepare, send, and monitor print jobs through Bambu Studio without transferring files by USB drive.
Please let us know the preferred IT/network approach for connecting this device.
Sorry, I did not consider the need for WPA2-Enterprise/802.1X authentication (available only on the Pro version of the H2D) when I suggested LAN-only mode.
I considered suggesting a separate subnet and routers for the printers with appropriate firewall rules, but your IT department would probably just label you a troublemaker and show you the door.
