Show me your smart home integration :)
Curious how others have integrated their Bambu printers into their favorite smart home system (Home Assistant, openHAB, etc.).
Personally I just have a very basic read only integration. Can’t do much beside checking most important parameters.
What y’all got going?
This looks pretty nice and handy but the manual is in german.
I used these guides. Made it pretty painless. Bambu Lab Guides
Nice resources, thanks for sharing.
I use Home Assistant and I have installed the Bambu Labs Integration from the Community Store.
I was having print failures with ABS and ASA if the print stared before the chamber was warm enough, I found that I need the chamber to be at least 37c to get a successful print with those materials.
I created an automation to check the chamber temperature when a print starts with the print material being ABS or ASA. If the chamber temperature is too low, the print will pause and wait until the chamber reaches the minimum temperature that I specified and then will resume the print.
I also created a set of automation’s to turn on my Bento fan to filter the air inside the chamber when I print ABS or ASA and turns the fan off 5 minutes after the print completes.
For one print I wanted to speed up the print once it reached a specific layer, so I created an automation to put the printer in Sport mode once that layer was reached.
