Slice Uneven Lines Shown Help
Hello,
I’ve noticed this when creating AI to image files. When I import the file into bambu and slice it the slicer shows these uneven top layers. Does anyone know why this occurs and what setting to change or settings to change to resolve this issue?
Because AI isn’t perfect.
Because AI is not perfect and it makes some assumptions depending on the color differences in the picture or interpret shading. Your uneven lines are just part that are not on the same plane so they’re printed at different layers. I bet if you scrub the right slider layer by layer you will see they’re printed as a one layer difference.
you can increase the layer height so that they may come on the same layer but then you will loose a lot of details (the small designs at the bottom are already not fully printed). There’s unfortunately not much you can do other than designing the part yourself…
Thanks! I actually was looking at the layers and saw it’s basically uneven. So I basically ditched the AI to file generation and went into tinkercad and created a new design using that same design base just simplified it. Here is the simplified version I just created without the AI to model and it came out pretty good, no uneven issues and print time was also less. I’m stil llearning the ropes and again thanks for the response, I really appreciate the help.
well done, looks nice and clean
