Slicing create form
i have this
personal creation!
in assembly, that is selectionned is BIG form of, phone support without
logo!
but when i slicing model, this appear
and same i changing filing form or
this stay on!
problem is i need place for support, on model, better for this
because
and
get out
I am afraid that it is really hard to understand what you need. Maybe try DeepL for translation?
The green trees in the second pic are support structures.
i remade, same objet, nice!!
The problem arises during the "slicing" stage, when it processes the build plate!
It generated a shape on the build plate beneath the object, causing the support attached to the object to warp!
However, as shown by the slicing of the newly created composite—using the exact same base objects—it doesn't produce that discrepancy.
Ok. I think I get an understanding of the issue. Just summarizing in my own words to make it easier to spot misunderstandings:
  • Own design with a challenging print feature: The lower holding flange needs to be printed directly on a support structure before growing to join the main body higher up.
    => For this challenge I usually use a dissimilar material interface. PETG for PLA and vice versa. This allows the use of a 0mm top z-distance in support settings. Both materials need to be absolutely dry (i.e. self-dryed, especially (!!!) if new).
  • The support failed. This is not surprising with anything but a 0mm top z-distance. Warping/curling of the support may be an issue, but drying the filament and reducing speed (by half) helps a lot. Also, due to the long lever arm before the flange joins the main body, use 2 walls for the support trees.
  • The second set of pics still show the needed support. It has just moved from the build plate to the part. In my experience, it is better to place supports on the build plate, use 2 walls for them and use dry filament at slower speeds in case of issues. The pri ting of “islands” in the air requires a 0mm top z-distance unless “islands” are tiny and quickly join the main body.
D’accord. Je crois avoir bien compris le problème. Je vais simplement résumer avec mes propres mots pour faciliter l’identification d’éventuels malentendus :
  • Conception originale prĂ©sentant une difficultĂ© d’impression : la bride de fixation infĂ©rieure doit ĂŞtre imprimĂ©e directement sur une structure de support avant de s’étendre pour rejoindre le corps principal situĂ© plus haut.
    => Pour relever ce défi, j’utilise généralement une interface entre matériaux différents : du PETG pour le PLA et inversement. Cela permet de définir une distance Z supérieure de 0 mm dans les paramètres de support. Les deux matériaux doivent être parfaitement secs (c’est-à-dire séchés à l’air libre, surtout (!!!) s’ils sont neufs).
  • Le support a cĂ©dĂ©. Cela n’a rien d’étonnant si la distance Z supĂ©rieure n’est pas de 0 mm. Le gauchissement ou le recourbement du support peut poser problème, mais le fait de laisser sĂ©cher le filament et de rĂ©duire la vitesse (de moitiĂ©) aide considĂ©rablement. De plus, en raison du long bras de levier avant que la bride ne rejoigne le corps principal, utilisez deux parois pour les arbres de support.
  • La deuxième sĂ©rie de photos montre toujours les supports nĂ©cessaires. Ils ont simplement Ă©tĂ© dĂ©placĂ©s du plateau d’impression vers la pièce. D’après mon expĂ©rience, il vaut mieux placer les supports sur le plateau d’impression, utiliser deux parois pour ceux-ci et imprimer avec du filament sec Ă  des vitesses plus lentes en cas de problème. L’impression d’« Ă®lots » en suspension nĂ©cessite une distance Z supĂ©rieure de 0 mm, sauf si ces « Ă®lots » sont minuscules et se rejoignent rapidement au corps principal.
PS: Apologies if I misunderstood or jumped over a few explanations. This is quite a challenging print. You coul also use thr cut tool to cut it vertically and then join it post printing. This would avoid the need for supports and make it much stronger, but with a noticeable line down the middle.
P.S. : Toutes mes excuses si j’ai mal compris ou si j’ai sauté certaines explications. C’est une impression assez complexe. Vous pourriez également utiliser l’outil de découpe pour la découper verticalement, puis l’assembler après l’impression. Cela éviterait d’avoir recours à des supports et la rendrait beaucoup plus solide, mais il y aurait une ligne bien visible au milieu.
All fine, latest picture showing great result when i re-slicing and recreate all with same base object!
and 0mm on z support is for mix PETG PLA!! never if is same matter, scratch otherwise!
i put often to 0.36 or 0.27 if is surface plane or 0.18 for small piece but 0mm just if used petg on support for PLA!! and it’s better!
NO, bug is slicing!!
not same between assembly of same base objets!
and not first project this
So your problem is solved now?
I wrote that you need to use a dissimilar interface if you need a 0mm top z-distance.
I also wrote that the model geometry has a big, long lever arm while sitting only on the support. If that long arm is neither small nor attached quickly to the main model, it’ll wobble on a support with a weak interface during printing until failure.
The partial screenshots indicate the difference between supports on build plate only enabled and disabled.
But Studio is not bug free. Most bugs I have seen relate to memory issues so a restart (mainly Studio but sometimes the PC/Laptop) usually resolves them.
Either a bug or changed settings. Even a small change elsewhere can change the result of an optimization algorithm like tree support generation.
I never claimed it was. It is a challenging print. Good luck.
