Slicing overhangs
I wanted to print a grommet from TPU.
And when I slice it, the printer prints overhangs fist at the outer diameter and than inner and than filling the gap.
I want to print from inner to outer via rings (that one ring supports other outer oner).
HOW do I do this in slicer?
Now it does like in the picture. First inner, than outer that is in the AIR and than he want to fill the gap.
@LPKA Can you provide the .stl or a,link, can try here as well.
OK, here is the STL
RUBBER.stl
I really struggled to get the slicer to produce the image you posted. When I did it was with wall loops set to 1 and 100% rectilinear infill.
Set wall loops to 3 or 4.
thank you, it help I set 3 walls, 20% infill, and it did via inner to outer.
I had them at 5 walls.
Wil test it.
The softfever fork of BambuLab Studio allows you to choose several permutations of the sequence of outer, inner, and infill.
