Hey @ipmcc This looks to be a quality setting within your slicer issue. Make sure the walls and layer height is adequate enough to populate the model itself.
If the wall thickness of the model is 0.4mm, the setting for layer height cannot be 0.62mm, etc. The math needs to line up to be able to calculate the walls extrusion and layer heights
The thickness of the material in the model should be 1.5mm or greater.
I didn’t see the setting you were describing, but switching to “Arachne” yielded a good slice, and is printing now, so we’ll see how it turns out.
Thanks for your input! It got me looking at the settings which I’ve mostly ignored until now, assuming the defaults were best. I guess sometimes it pays to branch out.
I’m obviously far from an expert on this stuff – only about a month in – but if it works, it works.
Just as an aside with “thin” wall designs, in the CAD program I’ll double check the wall thickness by cutting away half the model (or whatever is appropriate) so I can check the cross section. If you use fillets or chamfers it’s pretty easy to pull them to the point where they make walls too thin in some areas.
I didn’t see the setting you were describing, but switching to “Arachne” yielded a good slice, and is printing.
The circular output funnel was absolute trash, but the square output funnel came out much better (although not perfect.) I think I just need to thicken up the walls. some more.
As for the settings, I mainly use OrcaSlicer which is a fork of multiple slicers combined into a single program. I use Bambu Studios as well to ensure my models are printable for every user.
Using “Arachne” as your walls setting is the go to parameter imo. This adjusts the [Wall Thickness] according to the model being sliced and adapts throughout the model. [Classic] will generate a [Specific] wall thickness which is a set variable within the print settings.
I’ve modified the model for walls to be, nominally, 2.5mm. (They’re obviously not coming out like that when printing. More like 0.5mm as measured by calipers, and pretty flexible/flippy-floppy – with apologies to Talking Heads). Very flexible, but upping the CAD thickness to 2.5mm has, at least, yielded parts I can use, even if I remain confused about why they don’t match the models.
I printed 4 of these models at a (CAD) wall thickness of 1-2mm, and they were always full of gaps. I’ve tried Vase mode. The “Detect thin walls” checkbox is disabled for me. I guess I’ll beef up the walls to be 5mm or something. I’m wondering if I’m fundamentally missing something here.
Regardless, I have two usable funnels at this point and that was the goal. I’m not trying to product-ize these funnels at all. Just trying to solve some household problems. And… problems solved!
