Slicing Tolerance option from Curas experimental settings
I’ve put this over in github too.
Part tolerance is not good for some mechanical parts, I have multiple objects that won’t fit together, however if I use cura on any of my printers and use exclusive mode in cura experimental settings, things work much better.
Explanation here Support Community
The only way to get it to work for me currently is to make a part smaller or bigger but then that presents it’s own set of issues with tolerances.
Can we get these added to bambu studio?
Going to add my two cents and bump this recommendation. The experimental slicing tolerance in ultimaker cura is invaluable for dimensionally accurate prints on my creality ender 3. Maybe not all users see the advantage, but as a mechanical engineer trying to make prototype parts I find this a critical feature. All of the calibration cubes and flow calibration tests are fixing the wrong problem if the slicer lets the print line extend outside the model boundary by default.
