Slopes, Angles dont look smooth. How can i fix it?
My Problem is that if i print a slope, that its not looking good. The lines are to far away from each other.
You can see it in the slicer too.
you can clearly see it in the Pictrures from the slicer.
I print with all settings Standard. I think i can solve this Problem with other Parameter. But i dont see/know which one i need to change to fix this Problem.
I hope you can help me.
I don’t see any problem there?
This looks exactly how 3D printing is supposed these days to work.
You can mitigate this lack of 3D printing with lowering the layer height - there is nothing more you can do.
OK so there is no option to lower the layer high only on slopes?
I need to say that today is my first day in 3D printing. So I’m a newbie.
I hoped that there is an option. The rest of the print looking flawless.
I’m not certain, but I think at this time you cannot add height modifiers with the Bambu Studio for another layer height.
You can try using adaptive layer height.
Different layer heights on the same print do not look very pleasant.
But honestly, the printer is so fast, I wouldn’t mind to print this whole model with 0.16 or even 0.12/0.08.
You could try playing with the value of the Wall transitioning threshold angle in the quality settings
It is defaulted at 10° , I have not played with this setting as of yet so I’m not sure whether you want to increase or decrease the value but I would start by dropping the value a bit to see it the slope lines are decreased or get worse
I would assume by reducing the angle that the transition lines would decrease
