Small gaps between some layers
Having a new issue with my A1 where there seems to be some small gaps between layers on my prints. Ive printed the same objects before without these issues with the same settings and same brand and type of filament, filament is dryed
any ideas as to what could be causing this or what i could check?
Have you figured this out? I’m having a similar issue.
The gaps seem close to the “architecture features”, have you tuned the pressure advanced well enough?
Can be a couple things, if retraction is on it could be retracting too much.
It could be the speed is reduced then sped up and not extruding enough.
I would recommend doing a Flow Dynamic, 0 to 0.1 with 0.02 steps, look closely and select the one with a perfect straight line.
