DarkMoon 3D in the US makes some quality smooth plates (not cheap nor inexpensive), as already recommended up top. But I’ve never used the BL smooth PEI so I can’t compare directly.
-Max
-Max
Here you go:
https://a.aliexpress.com/_mK5YUlt
If you search for smooth PEI lots of other sellers, I picked one up for around $20.
I’m surprised you don’t think supertack is not smooth. I thought it was very smooth and the only thing that ruined the appearance was the actual squish of the lines.
the BIQU Glacier plates are the best that money can buy…
There is no Supertack Pro listed on Bambu’s website. It is listed as the Supertack and is not available for the H2C.
It is available, just out of stock if that’s what you meant?
It is a bit weird, as it shows to be available for the H2D, but “sold out” for the H2S, even though they have the same size built plate.
The H2C variant is currently stated as “not available”.
I meant there is no Supertack Pro on the UK website. It is only the Supertack that is listed and it is out of stock for the H2C.
The build plate for the H2C is slightly smaller than for the H2D - they are not the same.
That is correct. I included the photo mainly so people can see the name of the plate.
I mentioned that the H2D was available and the H2S variant was not. And those are physically the same.
I know the H2C has a 20mm narrower build plate.
Hey, anyone found a Smooth Plate alternative for H2C? I need it to be as smooth as Smooth Plate for other machines
