Spaggeti after many layers on standard speed with bambus filament
Hi!
Any suggestions welcomed here. This print failed after maybe 20 layers with major spaggeti. Everything is standard. Speed etc. The filament is Bambus own PLA-CF. Printed with AMS. With supports.(tree) But the layers where this was needed was never reached.
What can cause such errors?. Where do i start experimenting to get a successful print?.
You dry your filament before print?
If you don’t it could be the reason.
Hi Fredric,
Is this your first 3d print ?
If so start off with plain old pla to test parts out and learn the 3d printer do to cf filament is not cheap.
I would not use the cool plate do you have any other bed plates ?
Change your spares infill grid pattern to none overlap pattern.
( Sample: Gyroid is a none overlap infill pattern easy to learn on with most filaments )
Also is this a group of functional parts needing to be strong ?
( If so I would up the wall count to 4 or more and the infill density 30% or more 5 top and 5 bottom layers minimum depending on the application )
Hope this helps you out happy printing :v:
I didnt. I will try that in the next print. But this was a new unpacked roll that came with the printer. Humidity where i store this is 35%. Bu
This IS one of my first prints indeed. I did print some other bits with the pla but this is a part that needs som rigidity so i thought o give it a try. It was included so it is also pretty much all i have right now. Waiting for more filaments now.
It might be failing on the biggest part there. It has some inner modeled threads. This would cause and overhang and maybe the speed is too high for that. If i make the outer walls thicker i might be better off. Thats a good tip.
Your answer helped alot. Thanks man.
Hello, and all good advice above. I’d suggest checking out the Bambu wiki for answers to some questions you may have. Below is a link to the section on filament, bed plates, filament drying etc. This may be helpful in preparing the filament and bedplate for success.
Bambu wiki - Filament Settings
Might have been a minor clog on a layer. BL does not recommend using the .04mm nozzle with CF or any filament solid additives for risk of clogging.
