Spaghetti on prime tower
The strings are created if the the “Adhesiveness Category” of the different materials in the Tower don’t match.
And with the “Interface layer pre-extrusion distance” you can define the distance. So setting this to 0 removes the extensions.
Alternatively you can equalize the “Adhesiveness Category” number in the filaments to disable this also.
It is there by design, but for some cases/users it doesn’t always seem to work.
EDIT:
If you edit in Windows the following file:
%APPDATA%\BambuStudio\system\BBL\filament\fdm_filament_common.json
And change:
"filament_tower_interface_pre_extrusion_dist": [
     "10"
Into:
    "0"
You have disabled the behavior for all filaments without the need to edit all individual profiles.
Or optionally set it to a shorter value if that helps also.
