“Looks” really good. Extremely upgradable and basically a slightly cheaper voron 2.4 with some cool design changes. This is the sovol that sovol should have made.
4 llonger inear rails and 4 long extrusions gets you whatever print height your heart desires.
Good middle ground between a tinkering kit and a RTP(ready to print) setup.
For me personally, I would just go with a 300mm ratrig for $300 more or wait a while since eryone printers usually suck
He does a couple prints after adjusting the belts that look perfect.
Not sure what board it uses but you may be able to just plug a wifi dongle into a usb port. This is what they did with the Plus 4. Makes the wifi portion upgradable
Just to be clear. Not only other 3 printing manufacturers are your competitors. Basically they don’t even interest me anymore (except for one).
e.g.
Motorized 3 wheel bikes are a rapidly growing market in the USA.
A “Puckipuppy Husky” is almost exactly the same customer group as the customers for an X1C. You’re not just competing with other 3D printing manufacturers and when I ask myself whether I want a new 3D printer or a new 3 wheel, it’s the 3 wheel because 3 D printing is still doing the same as it did 2 years ago, so it’s better to wait. Since there is currently less need for 3D printing, problems have been solved better and there is too little innovation for to less “new probelms solved bringing cash” in semi pro 3D Printing.
Jups, it is Flashfroge. Well not becouse they do everthing right (Flashforge Creator Pro 2 - Something went very wrong there too), than I even just look on the outstanding unit becouse of TPU.
And I see even the small drawers and handles than may I will get also interest what he thinks.
Something really personal were no one needs to agree with me, if I wold replays my X1C I would check lidar and the dimension of the baldpate, access to the printhead (reduces maintenance tame overall) and spaghetti detection out of the box.
Or in the simplest words: 3D printer is interesting, but reading about it gets boring.
I once heard something like “bambulab, too big to fall” - oh my god, what would I do if Bambulab no longer exists tomorrow? The problem would be so small that I wouldn’t even be interested in the answer to it now, since the alternative backup printer is already next to the X1C…
My desired 3d printer:
Fully enclosed heated chamber. VOC Filtered
Dual tool (one tool for AMS, one tool for external spool -CF filaments, support…)
350ºC max temp
At least 30x30cm plate, 120ºC
What kind of transparency I’d like to see coming from 3 d printing manufacturers, especially from Bambu. Have you noticed too? [hint: Reasons to avoid]
Subjective impression, and also noted by NBR, is that it appears to be filling the infill faster than most other printers:
It’s a pitty NBR didn’t do some speed comparisons with other printers. I suppose maybe you could simulate nominal printing times by running a standard profiles in Orca slicer and taking note of what the estimated print time is. The Orca slicer estimates for Bambu printers seem quite accurate, but for some other printers there can be quite a deviation.
I wonder whether the 700mm/s in the thumbnail is just the travel speed, or whether it might actually be print speed for at least some scenarios?
I actually watched the video, which is a lot. But the bottom line is that the 400 x 400 mm has been discussed here many times.
The question I asked myself: If the printer only cost $400, would I buy it? The answer would still be that more space used than solving problems is not efficient enough to make smaller parts with. And the printer wouldn’t compete in the field of 400 USD printers if it wasn’t just about size.
If it’s just about the size you could take a look at it, but my trust in the brand is gone at more than 400 USD and even then I will look 3 times and more on it before i buy. And they can’t afford me to watch it three times on it… So if 3 development stages from printers are delivered one after the other, then I might start thinking about to buy something of Creality
That a common misperception. The parts you’re printing on a large format printer don’t themselves necessarily have to be big in order to derive benefit from a large format printer. You can instead produce a large number of smaller parts and run it overnight. For instance, if you’re into gridfinity like some of us are, you can print a whole bunch of the little organizer box inserts in preparation for inclusion into a larger case. Or, another example would be that at the moment I’m printing off a bunch of PEX pipe clamps in preparation for hanging a bunch of PEX in conjunction with water heaters and a return loop, not to mention a water softener and various water filters, all of which are to be neatly mounted inside a utility closet.
Also, depending on your printers part cooling fan, you may need to space parts further apart in order to print them properly with proper cooling, and so you may need a bigger build surface to facilitate that.
That said, one could argue that you’re better off with 4 A1’s than one big printer if you’re primarily printing smaller parts, because then your throughput is 4x faster. That’s true, but if you ever want to print a monolithic big part (even if it’s just occasionally), you get that flexibility with the large printer. It’s by reasoning such as this that lead me to think that a constellation of inexpensive printers is perhaps the most powerful, as opposed to the one printer to rule them all. The main challenge so far has been finding enough space to put them all, and also the non-trivial amount of time to tune all the different print profiles.
There are many approaches were you are right. I do not disagree, i just add.:
Small parts and larger plate usually only helps with a color change. (More smaller part by less colorchange - if thats a topic how matters to the user…)
And in general, I have generally stopped using PETG and ASA for large parts. A special reason why this also happened at PETG: Massively more cases of damage for parts that had been in transit for more than a year. More expensive forms of production were used again as 3D printing proves limited usability for bigger parts anyway… or the material and printers become massively more expensive (so may one more 0 at the end) and a professional is needed since I don`t have the time for to do it.
And in order to get more smaller parts on one plate, spagetti detection is more of a priority for me than larger printing plates - or you can simply place 3 Flashfroges M5 next to each other - Then the parts are finished before even the night starts or you have parts yourself if a printer breaks…
Well and by the way, Flashprint has many disadvantages. If is there one advantage on flashpribnt: To control an arm of printers at the same time. Sending a print job to as many printers as you want at the same time.
2) Will Bambu publicly commit to never restricting the use of third-party filament in any way, shape, or form?
For our current product line, yes. We have no plans to restrict the use of third-party filament in any way.
Yes they might have some proprietary resins in the works (from the trademark registration: artificial resins, semi-processed acrylic resins, semi-processed natural resins, semi-processed synthetic resins) and the resin printer will only work with them.
It’s certainly possible, however just because they have that stuff in their trademark doesn’t mean they are going to make them. The reason they would want to be broad is so that nobody else can call their company “Bambu Lab” and sell laser engravers—that would be very confusing for consumers, hence why they added that class.
(I am not a lawyer, this is just what I understood from brief research)
