As some pointed out, I AM damaged goods when it comes to 3D printing.
I started during the early days when all we had was 3mm filament of questionable quality LOL
I am actually quite happy with my print results now, nut it took quite some time to get things right…
I really like to calibrate every new colour or material I add - from scratch and totally ignoring what Bambu has in mind as I find their defaults, how shall I say it? Unsatisfactory…
Have get the camera out one day to upload some pics I guess…
Take the dreaded top surfaces…
I have seen an endless amount of corresponding topics, all discussing how to get this vital layer look perfect…
Ironing, slight changes here and there but in most cases the result only gets a bit better but never reaches a quality I would consider good enough to sell a model like this.
I found that Bambu makes it way too easy for the user while at the same time making it quite difficult to get around certain issues.
Had to change my calibration and tuning routines because of this…
A top surface is NOT just the last layer of a model, it IS ALL top surfaces, with that whatever foundation they might have.
For some reason this seems to have got lost when we switched to faster and more capable machines/slicers.
The FIRST layer was always the most important one for a print, if you ask me then it still is.
This layer defines how well or bad the second layer goes down.
Since we usually print those first layers with 100% infill any minor issues keeps building up.
Becomes quite obvious when you try to print a test cube with 100%infill.
I can also find well meant replies where users recommend to NEVER use a 100% for inside a model - because it tends to turn into a mess… LOL
If you can’t get a clean and smooth surface with layer 3 then you never will…
And realistically already the 2nd layer should be perfect.
My flat top surfaces are smooth, clean and free from these bump lines around the outer walls.
There is no gap between the lines, no rough lines either…
No need for scarf seems on my end either…
An aligned seem IS visible but only a slight issues for tight push fits, for which I just sand over the seam if required.
With random start points I have a hard time finding these points and have to either feel them or grab a magnifying glass.
How did I get there ? Through ignorance and hard work LOL
Flow ratio and print temp come first on my list.
Then the K-factor, overlaps, retraction and so on.
Only after I am happy with the results I go and adjust the calibration factors for holes and outer dimensions in order to get the required accuracy.
I can design a M8 by 1.25 bolt and nut to DIN specs, print them and they fit together the same way they fit on the metal originals.
I don’t design with FDM tolerances in mind, I design to actual dimensions and print the parts like this.
Bambu has ease of use and high volume printing in mind, preferably only using their own filaments of course.
They did not re-invent 3D printing though and whatever we had to do in the old days to get good quality and accurate prints still applies the same way.
Yes, the defaults are MUCH closer to being usable than a few years ago but if you really want the lot you won’t get around proper MANUAL calibration.
And that only gets you as far as the flimsy hardware allows…
