I have had my R1 running for 2 days now. As it sits idle with the internal fan running it builds up a lot of static electricity. When I touch the lid to open it I get a terrible shock of static electricity. Is this normal? It seems to me that frame should be grounded so that this does not happen. Can I fix this somehow?
You could check that with a multimeter, for example by using the continuity or resistance (ohms) setting. Place one probe on the printer’s chassis and the other on the ground connection of a wall outlet. Do not touch the live or neutral pins.
If you’re not comfortable working around electrical installations, you could use the radiator instead, as it’s often connected to ground as well - or even a water faucet, if that’s easier to access.
One possibility is that the ground wire inside your R1 wasn’t connected properly during assembly. However, there are also several other potential causes. Static buildup can be influenced by things such as the type of flooring in the room, humidity levels, or even the shoes you’re wearing.
I’m not saying this is definitely the cause, but checking the grounding would be a reasonable first step in troubleshooting the issue.
Otherwise, it could also be that the electrician simply forgot to install a ground for this outlet.
Great ideas. Thanks. I’ll check the ground in the wall, the power cord, and the unit itself.
When you’re touching the lid are you talking about the plastic material? If so I don’t know how much grounding the machine’s going to help for static electricity on a non-metal lid. To be transparent they don’t have too many options on the material they can use for the lid. Pretty sure the machine is probably properly grounded. Your wall outlet may or may not be. Both of these options may not be helpful if it’s just static electricity when you’re touching the plastic.
Do you understand static electricity? FYI plastic is not required to be bonded for obvious reasons. As an electrical contractor and UL 508 panel shop I’m pretty sure I’m qualified to answer some of these questions.
Would not a properly grounded machine provide a static charge an explosive path to ground? Rather than prevent it? Using static floor and desk mats, as well as wrist straps, slowly takes the charge away, while a direct line to ground is often everything at once. Thus the shock.
Do you?
The biggest non-lightning static discharges I have ever seen (in person) have come from ungrounded plastic 55 gallon drums after spending 15 minutes on the tumbler in the dead of winter.
I am talking about several inch long, loud cracks blasting me in the hand when I reach into the thing. Enough to visibly light up the inside of the drum.
Hurts more than a bit. I ended up dipping an aluminum rod connected to a ground wire into the drum before reaching in to deal with it.
Exactly that false sense of security that plastic doesn’t need to be grounded in any way has resulted in more than one woodshop blowing up.
Not on a plastic lid unless you had a wire grid/mesh .
It’s not that it doesn’t need to be bonded, it’s that normal means of bonding will not work. You need a grid or mesh going across its entirety for it to work effectively. Some of the hoses on vacuums get around this by coiling a copper wire around the entire thing. This just isn’t feasible on the lid unless you want to see a cage. Some other materials will work that are non-metallic, but they aren’t see-through or readily used.
Edit. Most shops and garages this is not an issue as the floors are not carpet. I’m assuming they have carpet in the room they have this in. Or possibly laminate flooring and they have some sort of cloth desk chair that they’re getting out of right before they touch it
Blah blah blah. They said they are getting shocked when touching the lid. The lid is plastic (most of it where you would touch it). I was trying to help. There is NO point in checking grounding/bonding if getting shocked by plastic. A short in the machine would not shock you on plastic, poor bonding/grounding will not shock you in plastic. Why waste time, possibly buy a meter if they don’t need it. Your whole response is useless (no offense) if they say “yeah its when I touch the plastic lid”. Because nothing they do other than a mesh/grid is going to do anything. Letting them know about static electricity and what causes it is more helpful than sending them down a troubleshooting path that will not solve the issue. If they understand things in their room that may be causing the issue they might be able to reduce it (or not if its carpet).
If they are touching a part that is metal then yes the other responses are helpful. This is why I ASKED what material they were touching when this happened. Much more helpful than a rant about a company that may have had a few (out of hundreds of thousands) of machines that may have a wire disconnected. I simply asked a question and got smart A$$ comments in return.
EDIT. Also if it was a DANGEROUS situation they would get shocked every time they touch the machine and not just the first time they touch it each time they interact with the machine. If it happens only the first time they touch the machine when they walk up to the machine then it is static electricity. If its continuous its a short or an actual safety issue.
Quick Mystery solving guide.
Going off past experiences with the machine from memory. (do not keep shocking your self to test)
- Does it happen when you touch plastic? If yes its static electricity.
- If you stand at the machine and touch it twice do you only get shocked ONCE on the first touch but not the second touch? In other words. You walk up get shocked. but you can work with the machine and nothing happens until you leave and return. If yes its static electricity.
- Are you unable to touch the machine at all. In other words if you touch it you get shocked. If you stand still and touch it again you get shocked? If yes. STOP, you have a real safety issue. Unplug the machine and check for proper bonding. If the machine is properly bonded then have an electrician check your house wiring to that circuit as it should be tripping a breaker if it is properly bonded and still shocking you. A properly bonded machine on a properly grounded/bonded receptacle should trip the breaker.
Unless they’re standing next to a gas can or propane stove the static electricity is not a major concern for safety.
If its static electricity there is only so much you can do if its due to carpet. If its due to a cloth chair get a chair without cloth/fabric.
I didn’t try to drive anyone away. Look at my first post. I stand by all of my posts, I asked a question and offered a real reason to what could be causing it. There is NO need at all test anything if it only happens on the first touch. If it happens on every touch its an actual issue.
Keep going, keep going, your adding nothing useful to the first poster. Even if it was building up static electricity. Bonding will not solve or stop it if it happens when touching a plastic lid because bonding WILL NOT dissipate static electricity from plastic that does not have a mesh, cage, or coil around it
Let me clarify. It is not the plastic that gives the shock. It is the metal rim that you touch to open the lid. Clearly many people here do not own an R1 and should not be responding.
I checked the outlet and it is grounded properly. I will soon test to see if the chassis is connected to ground.
Some thought it was me generating the static. Well, it only shocks me when I touch the R1, and only after it has been running a while. It is in a room with 3 3D printers and nothing else gives me the jolt.
I want to thank those who think me too ignorant to know what static electricity is. But I guess that is what forums are for. Forget the facts, just bash the guy asking.
What materials have you been cutting? Is the fan running because it is just on or because you are activly cutting and it is exhausting? Have you been useing the conveyor belt?
Wow great responnse. good luck. If it only happens after a while, its static electricity. Keep going down the rabbit hole if you want. I simply asked a question on what material was being touched.
For others who are not close-minded. If you want you can touch something metal right before you touch the machine. Try touching the machine and see if it shocks you. If it does the machine is building static electricity and not you. If it’s something on the machine should dissipate if everything’s properly bonded and grounded. Plastic fan could generate static electricity
If you own an R1, do me a favor. Power off your machine and unplug it from the wall. Use an ohmmeter and test for conductivity between the internal metal frame and the ground pin on the power cord. The chrome rail that the head rides on is one easy test point. Now check for conductivity between the ground pin on the power cord and and the metal handle on the front of the lid. If you get conductivity on these tests, your machine is different than mine. If not, we are all the same. The frame on my machine is not connected to ground.
If you don’t own an R1, please do not respond.
Yes, have desk mats and floor mats in my little home lab.
My R1 is here now. I don’t appreciate trying to help someone that is asking for help and then when I ask a question I’m then told “Don’t respond if you don’t have an R1”. Electrical Theory and Physics don’t change. I also don’t appreciate that you jump down my back and throw facts about your setup at me to prove a point when those facts WERE NOT in the original thread. You just had a theory of what was going on, so a hand full of us asked questions (that we did NOT have answers to) and presented other theory’s.
We are here to just try and help. That is it.
Ok onto what I found on MY printer.
The lid is plastic. But it does have a metal frame that attaches to the metal handle. Mine is bonded properly. HOWEVER, the metal handle has a coating on it so my meter wont read continuity as I can’t get contact with bare metal. If I test from the screw of the handle back to the ground pin on the plug I do have continuity.
OP, Test from the screw of the handle back to the ground pin. If you have continuity then yours is bonded. If this works you can try removing some of the coating UNDER the screw (no real head on screw) or where the screw touches the inside of the hole and that will make sure it is bonded. Hopefully this helps.
