Strange Message - how to solve this? "The Filament Track switch....."
every time i see the following message after slicing :slight_smile:
“The Filament Track switch installed on the Printer does not match the slicing file.Please re-slice to avoid print quality issues”
How i can get rid of this?
Try to sync info on bambu studio
i get this Message, too. Printer is synced.
My program version is 2.6.1.55 (beta).
did all possibilities to sync - it´s on the “normal” version and in the new beta.
Pretty sure its just a bug in the App, i was getting the same before running a filament track switch and just ignored it
Is anyone else having the issue that when Dynamic Mapping is enabled and one nozzle is assigned multiple times, an error message appears saying:
“The diameter of the main nozzle (0.4 mm) does not match the diameter of the sliced model (0.0 mm, which obviously can’t be correct).”
Because of this, I can’t even start the print anymore.
Check the nozzle diameter on the printer.
Everything fine… everywhere its on 0.4mm and if i disable dynamic mapping (so every nozzle is assigned to 4 fixed filaments) it will work. But i want to activate it because it saves waste and time
Are they all updated?
Dumb of me but you have the right printer selected right?
I get this message every now and then as well. To fix it, I’ll run an automatic AMS detection at the printer. Then I sync Bambulab Studio and re-slice the project. I assume it is some sort of a bug or dementia on the printer side…
We get this with every print and ignore it. Pretty annoying though.
yes annoying, strange that there is no statement from Bambu about this
I have the same problem. This message pops up every time I want to start printing: The Filament Track Switch installed on the printer does not match the slicing file.
How do I get rid of this message? :folded_hands:t2:
Probably busy with bigger fish.
I am receiving the same message. I re-synced and re-sliced, but still got the same message. Has this ever caused any problems to your print or machine?
None. The message is a bug in the firmware.
I had same issues also issues with feeding form an AMS. Filament was not getting through. Switching PTFE tubes from A–>B and B—>A did cost me a few prints.
Also not working when installed the TPU Feeder. When you want to use this one then you need to disconnect the Track Switch power. (6-pin)
Support is horrible from Bambu Lab. Turning in circles. I was done withit and decided to disconnect the track switch and trow it in the trash can. Seems Bambu Lab is more in supporting influencers then paying customers.
