Stringing issue on internal solid infill
People of the print, I come to you seeking knowledge!
I’m currently trying to print two slightly different gems that I made in Blender, but I’ve been running into an odd stringing issue with one of them that seems to be related to how the internal solid infill is being printed.
These are the two gems in question, and as you can see, the internal solid infill is slightly different between the two of them. The reason for that is because the one on the left has vertices on the diagonal faces that are pushed out just slightly further than the one on the right. However, when you start to print them…
…The one on the left becomes a stringy mess, while the one on the right is just fine! I’ve kept an eye on the print while it runs to see where the issue starts, and it seems to be a result of the nozzle hopping from point-to-point while trying to print the upper parts of the internal solid infill.
As someone relatively new to printing, I’m not entirely sure what the cause for this might be. If anyone can point me in the right direction, I’d appreciate it! In terms of filament, I’m using Bambu standard PLA, and the internal solid infill pattern is set to rectilinear.
Could you please upload the 3MF file from Bambu Studio to the forum? You can just drag and drop it into the comments section. It’s probably an export error in Blender and not the slicer. Of course, there could be other reasons, but that would be the first thing to check.
ChaosEmeraldDemo.3mf (38.2 KB) Here you go! I know one issue I ran into previously while importing from Blender was a scaling/units issue, but I fixed that prior to this save. Otherwise, I don’t recall getting any errors.
The one shape has retracted travels, the other one doesn’t. And youve get ooze strings anywhere theres a retracted travel - I’d dry that filament, or check your retraction settings if chatgpt has told you to change things from defaults
First of all, the basic question: Why don’t you use infill? That would probably solve your problems. Is there a particular reason why they’re supposed to be hollow? Is it for LED lighting?
Example with infill:
If you want to try experiments like this, you should print them one at a time, not two at once. The printer should be capable of printing these objects. The problem is more likely to be oozing or wet filament.
Because of the unfavourable geometry and the fact that you’re printing two objects at the same time, the nozzle keeps jumping back and forth, over and over again. You can see that in the blue lines.
In a nutshell:
  • Check why the nozzle is oozing.
  • Print only one object at a time in this special cade.
  • Use infill unless there’s a good reason not to.
If it still isn’t working, feel free to let us know. :grin::+1: and, of course, if it worked out, too.
Guys, If I got it right these two are printed in one job, and in one bed, next to each other. So how it could ooze on one and will be perfectly clear on the other?
To me it does not look like oozing but more like on the bad one you got more under extrusion/and/or/sagging/warping and these lines do not stick to the below layer, and just the nozzle dragged them around. And you got like rubber band effect. The other seems to be good enough to stick well and got no issues.
So maybe the solution is to use support for the bad one, or some tuning on the fans and speed so it will not sag/warp.
Thanks for sharing the file and the photos, that makes the difference between the two gems much clearer. I agree with the points above about printing one at a time and checking the retraction and travel paths, and it is also worth drying the filament, since damp filament can make oozing worse even when the settings look the same. If the hollow shape is needed for lighting, a little infill or a couple of extra walls may still help support those inner layers without changing the look much. Please let us know how the next test print goes.
Open the 3MF file and have a look at the toolpaths. That should answer your question, even if you’re only printing a single piece. While that isn’t the main reason, it is a major contributing factor.
It will happens on both models, but on one of them it’s much more noticeable because of the travel path. If the nozzle doesn’t move back and forth constantly, then the ozzing is rarely noticeable.
Tick the Travel checkbox in the top-right corner:
The OP uploaded the 3MF for a reason. Why not actually take a look at the file? Don’t get me wrong - I’m not criticizing - but you could learn something from this case. :grin::+1:
I’ve played with this a bit, and I think the main problem is that the models are not actually hollow. The purple is not a wall - it is interior solid infilI. If anything other than Lightning sparse infill is used, the models are filled.
Why should I open the file as you already did and showed the toolpaths?
And secondly as shown from the OP one of them is a mess the other is absolutely clean. If the filament and/or profiles are bad and make oozing second clean sample is not possible. As minimum it will have strings from the other object.
Also the toolpaths should be travel, so there will be no extrusion. And what is shown on the picture is like rubber, which looks exactly as the layer did not stick, but get dragged along the tool path. And it does not stick because under layer is not where it should be - sagged or warped.
Therefore what I said above. Could be wrong, could be right. I heading more to the right side :smiley: .
And I am not afraid to learn or to admit I have no clue about something, but sometimes the things are obvious and could be answered by common sense, or common tech experience. :wink:
That’s just so disrespectful on so many levels towards the person asking for help. Nobody is forcing you to participate in a help thread, if you’re too lazy.
I tried to be polite, but let me put it bluntly:
Your first comment was full of BS and wasn’t helpful in the slightest. That’s why my friendly recommendation is to actually open the file and take a look. :grin::+1:
Hey Retro, OP uploaded issue description and pictures, I am commenting on them. You requested for the files, so you look at them. So simple.
Downloaded and looked:
also
hard learning.
Object with size 101.6x101.6x71.9, two walls, 0.12 layer, hollow and no infill.
Ohhh and tool head moves, what a miracle :smiley: .
Great, I’m really happy about that - and I don’t mean that sarcastically. Now, let’s compare the settings with your suspected causes: So, the print settings and filament profile:
  • warping settings
  • support settings
  • fan speed settings
That’s one of the great things about having a 3MF file available: you can check your assumptions straight away because you can see the OP’s actual settings. Something you couldn’t do before simply because you hadn’t opened the file. :grin::+1:
Hey all! Sorry for the delay in getting back to all of this, though I’m grateful for all of the suggestions you’ve given! I should also clarify a few things before I start with some test prints on this:
  1. The two gems in the pictures I provided were printed separately. I included them in the 3mf I uploaded just in case that might shed some light on things. Sorry if that caused any confusion!
  2. The lack of infill is intentional since I ultimately want to print these using a more translucent filament. I figured it would be a bit weird if you could see the infill through the gem in the final product.
  3. I did make sure to dry the filament prior to printing, so that base is covered.
As for all the suggestions I’ve gotten, I’ll start by trying the following:
  1. Adding supports
  2. Adding more wall loops
  3. Adjust fan speed (any tips on how to determine sufficient fan speed outside of trial and error?)
:rofl: :joy: :rofl:
Ok but neither the pictures nor the 3mf files has loaded translucent filament, as we have the files now for our dear colleagues joy.
I do not have any experience with translucent filaments to be honest so no clue about that. But this objects are not small, but the layers are small and this dimensions I could imagine this thing will sag while it prints :smiley: . Support could help but may add bad finish. Maybe you can dial a bit bigger layers?
For the fans if you are not using some kind of custom profiles usual Bambu profiles are heavy on fans ( from the file :rofl: we can see Bambu PLA Basic which is all the time 100% part fan… ).
No infill and hollow are not the same. Neither MasterEmerald05.stl nor MasterEmerald5.stl is hollow.
Try this one. MasterEmerald05.stl, exported to Fusion, outer surface shelled inward by 1mm, exported as Hollow_Emerald5.stl, same process settings as ChaosEmeraldDemo.3mf.
Hollow_ChaosEmeraldDemo.3mf (33.6 KB)
Infill pattern no longer matters, as it only exists in the large bottom facet.
Better not hit him with facts. He put me on ignore immediately after my post.
It’s a shame that some people forget that the point here is to help newcomers and build a welcoming community. Unfortunately, this isn’t the first time he’s been known to engage in troll-like behaviour. Jokes are one thing, but giving misleading advice can ultimately ruin a newcomer’s printing experience.
Like this completely false statement:
The problem already shows up on a layer, where adding supports wouldn’t make any sense anyway - and he’s still yet to explain how any of that is supposed to help with stringing in this case.
That’s exactly why I wanted him to open the file in the first place - to check the geometry and infill settings. Instead, he just made fun for suggesting it. Classic. :grin::+1:
Thank you for letting me know! I am still new to the 3D printing, no shame to stand corrected.
Maybe some guys around would like me more if my printer was with just print quality and I was not writing about my problems, but was praising bambucha 25/8 :smiley:.
