Stringing Problem with eSun PLA Basic
Hey!
So I had my A1 mini for a while now and only printed plain white Bambu PLA Matte with it, which just worked. For a birthday present I bought this red PLA Basic from the company eSun. I used the Generic PLA Profile. When printing the first time, the model hat many weird strings coming of it and the printer also shot parts of the strings through the room. I tried looking it up and saw, that the box has “210 - 230 °C” for the printing temperature. I put that in a custom filament profile based on the generic PLA in min and max temp.
It definitly worked better but still not well. It also took almost twice the initial time. I have to admit, that I haven’t invested in a dryer yet, but I started printing right after taking it out of the box.
Do you have recommandations how to fix that? Do I just need a Dryer or is there something else I have to do?
If your filament isn’t dry, there are no settings on earth that will stop moisture related issues.
Okay I was afraid that thats the answer. Is something like this from sunlu enough or should i invest more?
I bought two spools of eSun PLA black on sale from Amazon a couple months back and no matter what I did it produced horrible results, I tried drying it, altered settings absolutely nothing worked, and that was on my X1C. I ended up returning both spools for a refund. I genuinely think it was just a bad batch as I’d not had these problems with eSun before.
Yeah I’ve been printing for two years, for the most part with PLA. I’ve never invested in a dryer, and for the most part I’ve never had any filament issues, even though I store my filament in the open in my somewhat humid basement. It does seem unlikely to me that PLA filament would absorb a so much moisture within a short amount of time, so I would think it was just from a bad batch of filament if I had none of these issues with other filaments. Don’t take my word for it though, I don’t have much experience with these kinds of issues.
Just put the spool in the cardboard box it came in, place the box on the hotbed and set the heating to 50 degrees for 12 hours. Poor man’s filament drying, but it works wonderfully.
Good luck with that on an A1 mini lol
Should work with the cardboard box the spool came in when it’s closed. There won’t be much air circulation to let the heat escape from the box. But I’ve never tested with a build plate smaller than a spool box though :smiley:
High confidence that is just simple wet filament, which is an easy solve
The regularity of the stringies and their length though hint to me that Timelapse Is Enabled? If so, turn that off, and youll remove a long travel, which will remove an opportunity to generate a long string.
I was having the same issue with white.
What’s wrong with the A1 Mini?
It’s not ideal for drying filament with
My A1 Mini-AMS HT setup would beg to differ.
Well yeah, that’s cos you’ve got extra equipment
What’s the difference between that and the:
-P1S standalone
-P1S + AMS combo
-X1C+ AMS combo
-Any other Bambu printer that comes either standalone or with the AMS 1
None of those options dry filament without extra equipment either.
Did you read the flow of the original convo or did you just come here weeks later to attack me?
The OP clearly states he has an A1 mini
and yes, you can dry filament in an X1C or P1S by using the heatbed
Considering I was the first person to respond to the thread, I’m gonna go with “yes”.
You gave a zero-effort, glib response to OP, I’m poking holes in it.
