Studio crashing after sending
studio keeps crashing after sending (Mac Tahoe M2).
then, I have to force quit because studio is frozen.
Also, studio will not start until mouse moves.
Frustrating!
Sounds like potentially a network plugin issue.
I would start with a nice clean of the register with CCleaner (free) then reboot and do it again…
What is your Studio version?
Has it ever worked for you on this same computer?
Have you tried using an older version of Studio?
What exactly do you mean by “crashing” in the first sentence then? That it freezes? Or it seems to exit but is still running in the background?
Not sure about the mouse movement bit at all… can you describe that in more detail?
Just to be clear, these forums are mostly for user-to-user support. To report a problem or get official help from BL it is best to contact BL support directly and/or file an issue at Issues · bambulab/BambuStudio · GitHub
a) Mac, b) Studio (or plugin) doesn’t keep any settings in the Windows registry.
All settings are in the local user-specific Studio configuration folder.
On Mac this is
~/Library/Application Support/BambuStudio/
for the release (non-beta) versions, and ending in BambuStudioBeta for the beta versions.
It may indeed be useful to try renaming the configuration folder and trying to start Studio again. All settings will be reset (the new user wizard should pop up), which may be acceptable or not, but at least provides some diagnostic information.
A more selective approach to removing the network plugin would be to delete the
~/Library/Application Support/BambuStudio/plugins
folder specifically and then restart Studio and let it install the plugin again.
HTH,
-Max
