Studio only allowing PLA at SEND TO PRINT drop down
Here is the situation.
At the Send Print Job pop up screen I am getting a Red Circle with Exclamation Point for the Filament selection drop down for everything but PLA.
(I have an A1 with no AMS)
I just updated to the most recent Studio Version and went to reprint something that needed a size adjustment. I was using PETG for the print and now at the Send Print Job pop up the Filament section I am getting a message that says " UNABLE TO AUTOMATICALLY MATCH TO SUITABLE FILAMENT. PLEASE CLICK TO MANUALY MATCH" When that drop down is clicked there is nothing to select.
The dropdown message
The dropdown with no filament
The PLA is the only thing that works
Screenshot 2025-05-04 084429
There has to be some setting that changed. I have looked all through Studio and am at a loss.
Things I have tried.
  1. Unsinstalling / reinstalled Banbu Studio
  2. Unselected /reselected filaments
  3. Disconnected my A1 and reconnected
  4. Verified everything is up to date.
From the printer:
  1. Use the filament button
  2. Select external
  3. Set the filament type to PLA (choose the closest match) and colour
From Bambu Studio:
  1. Select the Device tab
  2. Select edit (pencil) on the Ext Spool
Until the printer knows you have a matching type of filament, it cannot perform the auto-match feature, and you cannot do a manual match.
You cannot have the printer think you have PLA when you need to print with PETG.
You must have both the same before you can proceed.
Thanks for that.
Issue resolved. I would never have figured that one out on my own.
You are very welcome, that is what we are here for, to help others.
Hi,
I’m having the same issue and the fix suggested does work.
However, as I don’t have the AMS, in the “prepare tab” and under “project filaments”, the only filament I can use is the one that under “AMS filament” and before the 2.03.54 update I could use anyone.
It looks like my A1 thinks I’m using AMS and it cannot recognize the filament.
Any fix for that?
Thanks
Yup. I don’t know why I did not think of that. I remember distinctly setting this up when I first bought this A1. I spec I forgot. Thanks for reminding me. BTW, I tried to find an answer to this issue about a week or so ago but got no love. Searched today and there it was as if I had listed the problem myself. Thank you so much.
Why is this suddenly necessary ? I have had the printer (no AMS) for over a year and always only set the Filament type in the Slicer. Is there a setting to go back like it was, i don’t want to have to set it twice.
I have the same question. Will I need to manually select for every filament now?
It appears that there is enough difference between PLA and PETG plastics that the printer itself has to know what is expected of it. I’m with you, why should we have to change it in the printer every time we switch. All I can think of is because of the incompatibility of the plastics, and they don’t want you to end up with a bad print. I have gotten used to it, but it is still a pain in the neck.
Hi, what worked for me is to select the filament in Bambu Handy and add TPU in the external spool, only then could I select this in Bambu Studio. Perhaps this is what was meant in the solution reply above, but it took a bit more problem solving to find this setting in the app not on my printer.
Thanks for the previous replies, as others have said I would not have this myself.
Hi! I had this problem as well tonight except it wasn’t finding my PLA. I found out it was because it logged me out. Once I logged in and it found my printer and let me continue to print. Silly but I’m new to 3D printing and Bambu Studio and didn’t realize it. I googled it and tried restarting the printer and program and calibrated the printer before I realized this.
