I’m having problems printing PA12. Bad layer adhesion. I’ve increased the temperature in Bambu studio, minimum 265, maximum 285, but the slicer outputs at 260 and is unresponsive to my command. Is this a bug?
For adjusting the nozzle and bed on the X1C, you would change it like this, as shown in the screenshot.
The red lines indicate the nozzle temperature, with the minimum and maximum values representing the nozzle temperature range required for filament changes.
Ok, thank you, that might very well be the solution, thanks for your help
