Anyone else experiencing this?
I select import file, pick the file I want and the text window opens that says loading file and that is as far as it goes. It doesn’t do it all the time.
Have you checked the file itself?
It might be corrupted.
it’s happed with quite a few. It did it tonite on a model I made an hour ago.
I had to use task manager to shut down studio. The third restart worked.
Kinda frustrating.
There was a version on Windows a while (3-4 months) ago that was quite unstable and showed similar symptoms.
But that was fixed reasonably quickly after. I haven’t seen that behavior after that anymore.
What version and on which OS are you running?
