I have a simple hole filter/mesh. The model is fine, but when I slice it, the mesh disappears.
Prepare view:
Preview:
What am I doing wrong?
Prepare view:
Is the mesh thinner than the layer height?
If your design has a 0.1mm mesh and a 0.2mm layer height, the mesh will not be printed.
Are the walls of the mesh too thin?
Same logic as above.
You could choose Archane as the Wall generator type as that may improve things depending on wall and height sizes.
You find this is the first tab of the global settings, under the filaments and layer height, about 2/3’s of the way down the list.
Consider enabling Arachne in the Quality section Introduction to wall generator | Bambu Lab Wiki
The mesh looks like it might be thinner than the nozzle width. You might be better to import the model as a solid and use a modifier to remove the top and bottom layers to create the mesh.
