Hi All.
Hope any of you can give me some advice regarding an issue that has developed with my X1C.
It has 341 hours on it (bought around easter this year), and has suddenly started under extruding during prints.
It has so far only printed with plain PLA, so I don’t expect the issue to come from there, yet.
You can see 3 examples of the issue in the pictures below.
What I have done so far:
- Ruled out the AMS setup, by feeding filament directly in to the print head without any tubes connected.
- Ruled out the Slicer (Orca Slicer 2.1), by printing a pre sliced object from the printer.
So far I have tried to see of there was any foregin objects in the hot end, I did a cold pull of the tool head, by doing that I seem to have pulled out some PTFE shavings/fragments, which seems to have come the PTFE tube connector in the tool head, as there were a lot around the tube when I pulled it out of the PTFE connector.
But haven’t seen any improvement in the print out, see the PA tower picture below.
What I have planned on doing next is to do a hot pull as described on the bambu lab wiki, and take apart the extruder mechanism to see if there should be any issues there.
Do you have any other ideas what the issue could be, firmware issue maybe ?
I know it printed fine on 1.07, currently on 1.08, is there anyway to try to downgrade the firmware ?
I any case, thank you for your time.
Her is an example of the calibration lines, they are not connected as you can see.
Here is an example of a pre-sliced print from the printer it self.
Here is an example of a preassure advance calibration tower which contains lots of holes in the walls.
