Sugestion: Unload + Load Option
I would like to see the function “Unload & load”.
Reason: The Nozzle temperature can be hold. Its faster and probably even less power consuming.
It can also be named “change” to have a it a bit more precise.
Userflow:
Hit Change.
The ususal Unload procedure starts.,
After succesful unloading, the nozzle temperature does not change and on the screen you can display “insert filament”
and then
[DONE]
[CANCEL]
With done the Load process starts.
On my old Anycubic, you have to leave the load and unload filament screen for the extruder temperature to drop. As long as you’re on the screen, the temperature stays at the preset. Makes swapping more convenient. So I agree with you on this idea.
