- No. I got everything I need.
- Yes and I would go as high as $250
- Yes and I would go as high as $150
- Yes and I would go no higher than $100
- Yes if it were under $100
_________________________________________________________
Open comment to Bambu, if you’re listening:
You’ve described the community as “DIY-spirited community” in the Spaghetti Monsters blog.
Given that understanding, Bambulab clearly knows that many of its customers are constantly tinkering with our setups and therefore value options to enhance our experience.
So here’s a simple idea: offer upgrades to legacy printers. Give people the opportunity to enhance their printers with better and newer options. We get to trick-out our rigs, you make money. Isn’t that fair?
Here are just a few ideas (obviously biased towards the P1 given its customizability), but I’m sure others will chime in with even more imaginative suggestions.
- Offer the removable nozzle as found on the A1 as an upgrade to both the P1 and X1 series.
- A color touch screen upgrade for the P1 series or even just an improved larger format mechanical button front panel for the P1 series.
- Right-hinge door option or better yet, split door option to allow the glass door to take up less room.
- A purpose-built storage platform that has maybe a set of split side by side drawers to store one’s tools. It doesn’t have to be big, perhaps maybe 40mm - 60mm in height. There are enough examples on the web to show that such a thing has interest but none of them are a single unit purpose-built integrated item that enhances the appearance and functionality of the printer.
- Improved camera with higher frame rate and perhaps the ability to focus the angle to specific areas. Right now, the current camera is not very good for the P1.
- Better light options or the ability to place a light in a different locations.
- USB interface or wired LAN Interface add-on.
