Two years ago Bambu Studio introduced filament profiles for SUNLU filaments.This shows that they are open to 3rd party filaments used officially with their printers.
Unfortunately these print profiles are available only for A1 mini, A1 and A2L printers.
For other printers there are only Bambu and Generic profiles.
This is a request to update all printers with SUNLU filament profiles especially P2S and X2D printers that become a second most popular option right after A1.
While filament profiles for A series printers cover only basic materials PLA/PETG of course for P and X series it should cover more advanced materials such as ABS, ASA and PA variants.
In case it helps, SUNLU publishes some profiles here (in the “Material Labs” section on their site, which wasn’t obvious to me at first).
The original SUNLU profiles included with Studio were contributed at one point by a 3rd party developer. Since then BL has had to maintain them as needed when they add new features or re-organize things (but this doesn’t mean they’ve tested all those changes). I can see how that might be annoying, at best. Frankly I’d expect the original contributor to keep up with updates, or, as done in other projects with similar requirements, make sure a maintainer is assigned, for example someone from SUNLU in this case.
Another thing for BL to consider (or I would, anyway) is that by distributing profiles with their slicer, they’re kinda implicitly putting their stamp of approval on them. Or at least it could be seen that way. Now users might expect those profiles to work, or maybe even be “perfectly tuned.” But it’s unreasonable for BL to actually test and tune all the SUNLU filaments (heck they can barely keep up with their own). I think that creates a bit of a quandary. For an independent project like Orca this is less of an issue.
Having said all that… looks like someone already has taken some initiative on the matter! Though not quite as extensive in terms of coverage.
Those profiles don’t make much sense.
Nozzle temp as low as 235C, max volumetric flow at 15mm3/s and Textured PEI plate temp = 75C for standard SUNLU PETG?
Maybe I’m imagining things, but I could have sworn that I read somewhere that Sunlu actually produces some of the filaments sold under the Bambu Lab name. If there’s any truth to that, it could well explain why BL has provided filament profiles for Sunlu products. So the question becomes, “Does Sunlu produce filament for Bambu Lab?”.
I have found that print bed temperatures (for example) can be very different from my P1S to my X2D.
I try to NOT use a glue stick & just wash my build plates with Dawn & hot water.
I noticed that I was having adhesion issues especially when Bambu changed from PETG HF to PETG Basic.
I have found that I need to run PLA at a 65 degree temp in the X2D & PETG at 80 (sometimes 75 seems to work ok)
A lot of what I print are or would be considered “simple” designs, so I will typically increase the printing speeds (after the 2nd layer) to sport mode & eventually Ludacris after layer 5. I then found that I would have to increase the Nozzle temp (10 degrees usually works fine) to get proper flow for the increased speed
I don’t use a lot of Sunlu filaments, unless I’m looking for a specific colour not available from Bambu, as pricing (in Canada anyway) always seems better for official Bambu Labs filaments
