When I set the “Support/raft interface” to a different filament than the main filament being printed, the slicer only seems to use that filament at the top interface, but doesn’t use the different filament at the bottom interface. In this example, I used black filament for the interface, and you can see at the top of the tree there is black, but at the bottom of the tree there is not.
Is there a way to make both ends of the support use the alternate filament?
Thanks!
