Support Interface Option Bugged?
I have been experiencing an issue where Bambu Studio does not seem to apply the support interface option correctly. When choosing Rectilinear I usually get what looks like Rectilinear Interlaced and when choosing Interlaced I usually get what looks like normal Rectilinear? In some prints, I see a mixture of the two? An example of a mix is shown below…
Does anyone else see this or am I misunderstanding a setting somewhere? Coming from Prusa Slicer, I did not experience this issue. I strongly favour rectilinear only for my prints, interlaced leaves much worse scarring and is harder to remove.
It looks like it’s still an issue on the github Support interface pattern Rectilinear not working correctly · Issue #4374 · bambulab/BambuStudio · GitHub
I have the same problem and changing the angle from 0 to 45 like mentioned in the issue makes no difference.
Seems to have returned as a new bug in the latest version for Windows - setting rectilinear interlaced as the pattern for interface layer on normal supports simply shows rectilinear.
Setting the pattern as rectilinear interlaced for tree supports still works normally.
