j’ai beaucoup de mal a bien régler mes support, sur figurine modéliser par meshy!
l’idéale serait que mes support pour pont soit très proches comme pour soutenir plateforme (sous le vêtement mais sur les pieds), tandis que ceux étant pour les bordures externes devrait être éloigné, pour un retrait simplifié surtout sur partie fragile!
mais même en coupant la pièce selon différentes parties du modèles, le sous réglages ne permets pas d’ajuster le support différemment!
comme bordure ou radeau!!
les 2 ne s’applique en même temps car si tu mets 1 radeau, la bordure est oublié
If I get it right, you mean two type of support. One is close to the surface of your model and support less on another palce of your model. I think this is not possible in the Slicer settings.
I got very good results with supports with different material. For example: the model is printed in PLA and the support is PETG (and otherwise). The support is getting off very easily.
In Bambu Slicer under: Support/raft Interface → PETG (if Model is in PLA).
i have no problem for get off support, just a good z space between but it’s for under piece as a man with his legs and dress as priest, or as under car !! support is not clean under because have too much space!! but if i change it, cannot remove it clear
The wiki article contains all the important details about your problem. In short: If you’re printing with PLA, set PETG as the separator layer. Set the Z-Top Distance to 0 so that the PLA prints directly onto the PETG, which can be easily removed later. Check the wiki for the correct settings.
