Support settings - bottom layer despite set to 0 layers
Hi,
I would like to print a part with support, using support W for the top interface layers only. The bottom should be the part filament without an interface layer. Despite setting the botom interface layers to zero, it still lays down one layer, which does not even use the bottom interface spacing.
Hope someone has a work around. Support W and printing time are precious.
Hello. i confirm bug exists and is still present
I ask precisely for zero bottom interface layer. You simply cannot have 0 interface bottom layer. Tried everything from changing spacing, heights, patterns…
This is a real bug.
Have you looked to see if settings match in both global and object mode ?
Use support material for the Support/Raft Base also.
