So… I need to raise a ticket with BL.
The mandatory log upload is impossible though, as the websites allows me to select the files, but does not accept them…
Any ideas?
Any ideas?
Could you please share more information about the problem?
What printer are you using and how are you trying to upload the logs?
We have Wiki guides for all printers on how to upload the logs;
https://wiki.bambulab.com/en/x1/troubleshooting/upload-log
Please check them for step-by-step guidance.
Hi.
I tried uploading them to your website. The website doesn’t seem to take them. And when I then try to submit the ticket, the logs are obviously missing and I get an error message stating that…
Are you uploading the .tar.gz logs from the SD card? They are fairly big file size, the first time I tried I was trying to upload the wrong one.
I just picked the logs from my Mac folder and tried to upload. But the BL website doesn’t take them. It worked a few days ago, same machine etc, for another ticket that is still ongoing.
Please share the type of file you are uploading (is it an archive?) and the model for which you are uploading them.
That way, we can better troubleshoot this issue and assist.
It is not an archive. It is the three last files the machine generated *.log.0 and log.enc. Total file size is less than 6MB.
Please archive the files in a .zip format and then the upload should work as expected.
I am sorry, but this is just a bit of a useless suggestion.
However, I have tried, and I still get the same but I keep getting the same error.
As soon as I select the files to upload, I immediately get a message “Please upload the printer log files”. The website does not even take the files in question, I directly get the error message.
The file asked for when you open a ticket is attained from the export log button on your printer only afaik, it’s a big file that is .tar.gz format. I’m assuming other files are accepted once the ticket is underway but not the original upload.
This consistently doesn’t work and it is unnecessarily difficult to get assistance.
I get the same issue. I tried to attach the actual log files, .zip and .tar and .tar.gz each time I get the error “Please attach the log files”
I cant even submit a ticket to get help…
I also can’t attach a video recording here of the issue.
same things, i have the same bug as this guy
Are you on VPN by any chance?
Hello, I had the same problem as everyone else, could not upload log file. Tried everything suggested. Made one change and it worked perfectly. Stopped trying to do it from safari on my mac and filed the ticket on a pc laptop running windows 11. All problems went away. I have had this same type of issue with sites based in china and safri. Hope this helps.
I have the same problem. bambulab website support ticket creation doesn’t allow to upload log files and I can’t complete the ticket without adding log files. Sleek strategy to reduce the number of tickets !
save ticket as draft on pc mac or what ever, Open the Bambu Handy app, tap “Me” in the bottom navigation bar, then select “Support Center” to enter the Support Center interface.
On the Support Center page, locate the “Ticket Service” section and tap “Add a ticket”. Select the type of issue you are experiencing. Here, using Printer as an example, tap the “Next” button to proceed to the ticket submission page.
your ticket should be in there, just do logs.
