Support W Questions
I’m using support W as interface material for supports, using default settings,and I’m having a hard time removing supports. The support W is welded to the pla, hard to clean off without damage.
Wil adding some space help? Like.015mm? More layers of interface material?
Does moist support W become hard to remove? My last roll seemed alot easier? Maybe this one needs drying?
When it all works, it does great with supports, but it can be hard to remove.
So anyone got tips?
I’ve added a bit of a gap and it does help. I don’t remember how much I used but the bigger it is, the poorer the surface finish will be. If you don’t need perfection, try using the default of 0.2. It won’t be as pretty as the 0.0 that the pop up suggests but it will be super easy to remove.
