Hello!
I would like to see additional settings to adjust the order of concentric surfaces (maybe for some more surface types).
Especially with smooth and effect plates, adhesion becomes a big problem, whenever the concentric surface pattern starts in the middle, there are the biggest adhesion problems.
It would be much more helpful if this pattern started from the outside and only filled the last point in the middle.
Hello!
thanks… I noticed that too unfortunately I didn’t see any of those options for new or edited posts or threads.
… overall this forum is not very intuitive… i had to google and found a reddit post where it says you have to read several posts, spend time, etc before you can create a thread.
I got an error message about “You are not authorized for this action” … that’s not very helpful and leaves the user without any clues.
After I’ve established some “trust”… well… still a very bad user experience, I have to scroll through all the threads to the end to find the button: “Create topic”…
And now the idea of adding tags… No idea where I can find that.
