I have 3 different rolls of Bambu Lab Silk. Pink, Blue, and dual Orange/Red. With all 3 filaments I have noticed a top and side surface finish issue I can’t figure out or explain, that I don’t have with any other brand of silk filament (Flashforge, Eryone, GIANTARM, MIKA3D, etc…).
FYI - I print all silks @ 50mm/s for both outer walls and top surface, where prints already default to 50mm/s for the bottom layer, and never higher than 0.16mm layer height. What I am going to try and explain here is not an issue with the visible layer being too fast or too tall, and I print all silks at 230c.
Instead of trying to explain what is going on, let me show you. First up is a Tron light cycle I tried to print out of the Bambu Lab blue silk:
The print is using the exact same settings across all 4 bike chassis except for the other 3 are using the Generic PLA Silk profile with non-Bambu Lab silk filament.
I also noticed that just the Bambu Lab silk filament stuck REALY hard to the prismatic plates I was using, compared to every other filament. It was so bad that it left residue I had to scrub, not wipe, off, and I’m not the only one to report this.
This leads me to believe Bambu Lab has done something to the filament to try and make it print better.
The issues are very pronounced on the top layer as evident by these Unicorns I printed with Bambu Lab pink silk @ 0.16mm layer height (the top surface shouldn’t be rough like that at all), a giant fidget spinner that looks really bad on the top layer (I tried printed it with both the default top surface pattern and also concentric, both were equally bad with the concentric top surface being what is pictured), and then a top of a pumpkin print (printed at 0.12mm layer height) with the orange/red dual silk that got rough in a few random spots:
Then there are the issues with overhangs and surface quality as well. Not sure if it is in focus enough but hopefully the bottom of the pink tail on the unicorn is inexplicably rough. You can also see the bottom overhang is rough (I flipped it up for the picture) and some weird ringing on a wheel for the Tron bike:
I’m at a loss as to why all 3 Bambu Lab silk filaments have these issues consistently with top surface finish, side and overhang (even slight like in the Tron wheel), and generally sticking way harder than they need to every build plate. I’m also not the only one to have this issue as it happened to Frankly Built on his most recent video where he printed 4 Dr. Doom masks, all out of Bambu Lab Silk silver, and you can see on at least 2 of them that the filament is causing the same texture/surface quality issues:
Which BAMBU LAB 3D Printer is BEST…For YOU!
Again, no other silk filaments act like this, even close to this so I have pretty much sworn off Bambu Lab silk filament which is a shame since I love all their other filament.
