Swap X1C power supply for a better model? (chamber heater, LEDs etc)
Has anybody considered swapping their power supply with an equivilent but higher amps version from the same manufactorer? From my understanding the power supply in an X1C is a Mornsun LM100-20B24-C which can provide 4.5a @ 24v output.
So I am thinking, if I want to run things such as LED strips, Chamber heaters and such from the power supply (without having to plug a seperate cable in externally), then I probably need to up the power supply so I don’t interfere with normal power usage.
I was thinking to change it to a 350W power supply from the same supplier, something like LM350-10B24, LM350-10B24-C Mornsun America, LLC | Power Supplies - External/Internal (Off-Board) | DigiKey
Does anybody have any thoughts on this? I don’t see an issue as the specs are the same, it’s just that higher amps can be drawn.
That would be indeed a real improvement to the X1C if it does work and I’d definitely be interested in replacing the current power supply with a better one. If anyone does it, I’d be glad to learn how it went and if there were any problems. I’ll be keeping this topic under watch for any updates. Thanks for bringing it up @honkongkiwi.
LM100-20B24
Dimensions: 129mm × 97mm × 30mm
Cooling: Free air convection
LM350-10B24
Dimensions: 215mm × 115mm × 30mm
Cooling: Forced air cooling
Not sure how that would fit inside … and you’ll also need to make sure it can pull enough cool air. I think you’d be better off using an external supply.
For what it’s worth, X1E use a mornsun LOF450-20B24C with fan
Since you’re modding it anyway, instead of trying to fit it inside, you could print an enclosure and make it an external power supply.
I completely didn’t think about the size, but that seems obvious. So looking around it looks like LM200-22B24R2-CQ could work as it’s the same dimensions. This gives us 200w, which is a 100% increase, so I think this could work for a PTC. Also, the above linked PSU does not require active cooling (just like the original).
Downside on this is that it’s only 240v input that’s not a problem for me as I live in 240v country, but this might be an issue for some. I’ve just ordered it to test it out (found it for $13 USD where I live).
Let me know if I’ve missed anything here in the specs. I’m just a DIY enthusiast rather than an actual electrical engineer.
Although creating an external PSU is easy and possible, I just wanted a one-for-one swap option that gave me more power available to tap into inside the X1C for addons.
I don’t know where in the world you are located, but in the US, you can find Meanwell power supplies locally from Amazon for same-day or 1-2 days. Meanwell are decent power supplies.
If you go with the bento for filtering the VOCs and particulates in the printer, then you can remove the fan and stuff from the back for the chamber fan. Looks like you can get a larger PS in that spot.
Just replying here, this worked like a dream, no problems! An extra 100w to play with and a drop in replacement.
Even better, the printer only uses 1 of 2 screw terminals, which leaves a set free for custom stuff. It’s enough for a 100w heater, or some RGB LEDs etc… :smiley:
It looks like there’s additional length room in my X1C to mount a longer PSU, but you’ll have to design another power supply bracket (the origional one won’t fit anymore. Also, you’ll need an adapter bracket, but I think both are doable which opens up more models of PSU.
Thank you for sharing, I’m thinking of doing the same mod.
What’s the highest chamber temperature you have reached safely without damaging the printer itself?
And do you observe any printing quality improvements for high temp filaments like ASA/PC/Nylon?
Do you have some photos taken during the replacement, or a video of the process? Also, are there any lessons to be learned from or advices or tips about do’s and don’t’s? Do share.
I just did that swapping 100w power supply with 200w, it worked flawless!
Here too. No Problems after Swap👍
I used this one: LM200-22B24R2-ND
How are you accessing the additional amps of the new power supply? The internal wiring of the printer would likely limit drawing more amps through the existing connection points (i.e. 4-pin molex connector at the back of the printer).
I used the additional terminal connections of the power supply unit. I did not connect anything additional to the 4-pin Molex connectors.
An acquaintance has also converted it and connected an LED strip with BLLED to the 4-pin Molex. This has been working continuously for 3 months without any problems.
You could also just pull mains off of the power plug and replace the fuse with a higher one.
There is a new drop-in replacement from Meanwell.
Compatible worldwide 100-240V 50-60Hz input. 150W output not enough for a chamber heater but would allow some headroom for accessories and temperature derating.
There is also Mornsun LM150-23B24R2S, but due to US sanctions it is difficult or too expensive to acquire in some regions.
Fully Functional with a 24V 750W, PS is external all Wiring has been neatly routed through a hole at the bottom rear of unit.Used Quick disconnects and High Voltage Silicone Wire where needed
