Hello community, new Bambu user here and loving it so far. I have run into my first issue that I cannot figure out how to correct or work around and I am not even sure there is a way to do what I am wanting to do. I loaded a print for the machine to do before leaving for work and have been monitoring it from the Bambu app. Apparently something has jammed on the roll of filament I was using and it has paused the print about halfway through for me to inspect it to see what happened. Unfortunately I am at work so I cannot. I do have an identical spool loaded in another slot of the AMS to cover if the first spool ran out of material but I was not sure if I would be able to tell the X1C to switch to the other loaded spool instead of trying to continue loading the spool that is jammed. At least I did not see an option for me to do so and all of my searching on Google and otherwise is only giving me results for the auto refill feature which I already know about and use frequently. Can any of you more experienced users tell me if there is a way to do what I am hoping to do or am I stuck until I get home later to see what has happened?
Thanks everyone.
