Swaptek Head Idea: Dedicated Ironing Tool
Ironing currently takes a ton of time so whenever I end up downloading a print profile with it, I turn it off.
But what if on my P3C I had a tool that had a large (in comparison to 0.4mm) flat metal plate attached to the heating element, say 3-5mm, that could be swapped too to iron large sections quickly, then swap back to a 0.4mm nozzle to get the nooks and crannies? I feel like that might make ironing a little less painful!
very cool idea… but does ironing work that way?
It does not, the nozzles still needs to flow some filament to fill in tiny gaps. That is why there is a “flow rate” setting for ironing in slicer.
Oh, well that’s a bummer.
How about a slicer setting to switch to a fatter nozzle like 0.8 for ironing then? It would have to have the same filament.
In any case, my premise was wrong so I’ll mark this as the solution.
That might work, although I personally never tried ironing with larger nozzle than 0.4mm. Not sure if the result would be better or worse. Let us know if you try it out!
I know in general if you want the best ironing results a diamondback nozzle will be the best due to its smoothness and filament not sticking to it.
