As of this date, there is still no way to switch between AMS and external spool during a print, you are stuck with either using one or another .
This seems a very easy to implement feature through a firmware update as the hardware isn’t a limiting factor .
It’s probably one of the most wanted and useful features that are currently lacking and would open up a lot of possibilites such as printing filaments that are not compatible with AMS (TPU / certain abrasives etc) while retaining multicolor functionality .
The implementation can for example be done through gcode such as M600 in combination with a specific option that in addition interacts with the AMS board to disable it until another filament switch for enabling AMS is triggered, so basically a toggle to enable / disable AMS when M600 is called .
Adding my request for this as well. I have a print today where this is needed. Going to try the “pause” workaround listed elsewhere but something more holistic at the slicer level would be preferred long term.
Same problem here. Just designed a seal and need that to be printed in PETG and TPU on top. There still seems no way to do so. Has anyone already opened a request on Github? If not we should do so… I’ll try work around with “pause”.
Edit: Can’t get it to work with pause either grrr…
I too would like to be able to order, via GCode or GUI, the printer to retract the current filament on a painted model and either replace the spool in the AMS or change to the external spool.
What if you set TPU for your external spool and instead of using “pause” you use “change filament” and select N°5 which is your out of AMS filament (TPU in your case). I tried and it works in slicer (Orca, did not check with Studio).
I’m unsure if there was a firmware update to address this or if I got lucky. This worked for me without a pause or M600. I was able to print with 6 colors from the AMS itself.
Once you press print and are prompted to match the colors, I selected the first two colors that would finish first which were slots 1 and 2, once those colors finished I simply swapped in the new colors and the print finished without a hitch. My first test was 5 colors, the second was 6 but I think I can get away with 8 as long as you are spot on with which color finishes first second third and fourth.
Warning Message to select the slot
Well I would also like to have this feature!! I have problems with an external spool that dosen’t roll as it should. I believe it would work better in the AMS. But nope.. You can’t change midprint from external to AMS. This is really just bad.
