Synchronizing device information timed-out
Recently Im getting repeated “Synchronizing device information timed-out” errors that are delaying prints. Windows PC connected via Ethernet to switch that connects driect to X1c
Newest version of Bambu studios and X1C.
Any ideas what can be done ?
I keep having the same problem over wifi - eventually its able to print but syncing with ams etc takes many tries that all time out
Same here. Just started today. No SW updates that I’m aware of. Linux PC over WIFI.
same here on X1 C really strange
Pretty much always had it, just click retry and it works.
This has been happening to 1 or my 2 X1C printers pretty frequently. They are next to each other on the same wifi network. The refresh button does not solve it. I have to re-start the printer to eliminate this time-out. This hinders remote prints when access to the printer is limited.
EDIT: I found I can clear the error by power cycling my X1C, but this is really annoying and takes forever with 4 AMS units.
Same. Just started recently. X1C + 4 AMS over WiFi. After the error is displayed, I hit “Send” and everything works OK. Hoping Bambu will address this, as waiting for the time out message to appear is a workflow killer.
Same issue on P1S no amount of switching computer and P1S on and off and rebooting and refreshing in studio helps
Any solution? Same problem at p1s
Had the same problem on the a1mini with the AMS lite. The solution that worked for me:
manually edit each of the 4 filaments using the touch screen on the printer. This clears the error.
Same issue here with one of my printers. I can print but I cant upload (“Send”) project to the printer or access content on microsd. Restarting the printer does not help.
I can see the content in my phone or directly on x1c screen. Seems to be something related to the Bambu PC software.
I will try to format the microSD and see if that helps.
I had the same issue. Seems to have been doing it on my X1C for the last couple of weeks. As the previous post said, just did a quick power cycle and that eliminated it.
Bonjour problème identique suite de la dernière mise a jour j éteins et rallume a chaque fois la x1c
Same problem here. I’ve been printing nonstop since November without a single issue. Now everything is fracked up. Can’t send models to a1-mini, BS can’t sync to my printer.
Any solutions? P1P “Synchronizing device information timed-out” error is killin me.
Not sure if this is a solution for others but after turning off and on the printer, Bambu Studio, unplugging the AMS, etc… I rebooted my wifi and things came back to working. Hopefully that may be a solution for someone else as well.
I got the exact same issue with my A1, it has been like this since a few days. It always shows the error message and it does not connect with my printer anymore to view the camera. Weirdly I can still send the print data.
I had the exact same issue.
I could my A1 + ams lite to print after waiting for a few.
Then it would not print the next time. I power cycled the printer, restart the bambulab studio with no luck.
I had the printer hooked to a internet only wifi. I switch to my “internal wifi” and it worked immediately…
It had been working for month before that.
What has changed is that I installed the latest firmware : Version 01.06.00.00(20250812)that was not working (had the 4th ams glowing white all the time and could not do anything) Then reverted back to Version 01.05.00.00(20250603)
I hope it helps anyone.
Thank you Hysteric, reverting back to the previous firmware helped.
I had the same issue on my A1. My fix was that I was not logged in on the printer (despite printing for a long time and not logging out). I thought I’d post here in case someone has similar problems - push the settings button on the printer screen (it looks like a diamond) and double check you are logged in. Before I did this I turned the wifi on the printer off and back on too if that changes anything.
