I have an X1E, can anyone suggest some reliable parameters to print the Terrafilum PLA made from recycled materials? With the same print parameters it seems noticeably less reliable than, say, MatterHackers MH Build Series Tough PLA. Across ten parts I’ve had more than 30% failure rate.
What kind of failures did you get?
Typically the part splits all the way across one layer. Sometimes it is instead a spaghetti failure.
Sometimes increasing about 10 degrees the temperature of the nozzle help with this problem.
