The function to wrap text around a vertical object no longer work.
It was working fine until I download the latest version.
Pretty sure you need to check that ‘surface’ checkbox, so the text aligns to the surface of the object.
The text used to be straight and parallel to the print surface, now it wrap it as if it was a sphere or something.
No matter how I adjust the angle slider.
Check horizontal too.
It might be because I’m on 1.9.7.52, haven’t upgraded to 1.10 yet.
Correct, I only had this issue when I installed 1.10.
When I made this post, I was thinking it would be in the bug-report section, but I didn’t find it.
Thank you for sharing this issue! I was experiencing the same problem, but I found that reinstalling Version 01.09.07.52 resolved it. After doing so, I was able to use Horizon Text to add fonts again.
Here’s the link I used to download the older version—hope it help github.c
om/bambulab/ BambuStudio/releases/tag/v01.09.07.52
