Hey Bambu,
I have another brilliant idea for a software/firmware modification to the P1S and X1C printers. As it exists right now, the P1S and X1C reserve a region of 18x28 mm for the AMS filament cutter to operate properly.
My suggestion is a slight modification to the firmware as well as an update to Bambu Studio. Both modifications do roughly the same thing but in different ways.
First off, the firmware update would prevent (or perhaps simply warn) the user when they are about to move the print head into the reserved region. I have accidentally engaged the filament cutter and taken the magnetic front off of the print head with a sequence of naive X/Y movements. The quick fix is not to let the user move the print head toward the back of the machine while it is in this region. Movement forward into the region will collapse the stopper. Movement forward while in the region should not be problematic but may require investigation. Movement left should engage the rules of the restricted region and may engage the cutter, but it will not remove the magnetic cover. Movement to the right will disengage the cutter and eventually clear the region. Disallowing movements in the firmware that engage the cutter or remove the face plate would be ideal for new users and anyone who doesn’t know about this limitation.
Second, apply the same rules in Bambu Studio for Gcode that it generates. This would allow the full use of the print area, but it would restrict movement of the head back while in the reserved region. Again, movements forward and to the right are safe maneuvers. Movement to the left is accepted but engages the restrictions of the reserved region (and possibly the cutter mechanism). Movement back while in the reserved region should be prevented. This would allow full use of the area and collapse the stopper each time the head was laying filament in the restricted area while still allowing movement to the left that engages the cutter and is useful in AMS prints.
I hope this makes it into future updates, so that users may enjoy the full size of the build plate without needing to perform custom (and often temporary) modifications to engage the full plate area.
Thanks for reading. Discuss!
